a/c compressor
Old May 13, 2012 | 09:19 AM
olds w-31's Avatar
a/c compressor
dose anyone know were to get remanufactored a/c compressors with correct decales an markings.
Old May 13, 2012 | 01:51 PM
MaxDog's Avatar
I'm looking for the same thing. I want to keep the original stock look, but would like a little bit more efficient unit. I saw some remanufactured units on Year-One, OPGI, and I think the Parts-Place.
Not sure which one to get. Does anyone have any experience with these?
Old May 13, 2012 | 02:58 PM
Aron Nance's Avatar
I THINK there's an outfit out of Ft Worth (Old Air Products) that manufactures an aluminum A6 Look-a-like that is a 5 cylinder rotary internally. Visually externally looks the same as the original A6. Decals you should be able to get from Fusick's. Good luck. I am going with a Sanden conversion on the Silver Bullet. Weighs about 7 lb's and takes about 7 HP; the original A6 is 32 lb's and 25 HP when engaged!
Old May 13, 2012 | 05:03 PM
ah64pilot's Avatar
I went Sanden on my silver car...I haven't hook up the hoses yet but I'm glad to see it only robs 7 HP
I have the stock compressor available to anyone that wants to pay shipping. You could have it remanufactured if you don't already have a stock unit.
Old May 13, 2012 | 09:50 PM
DeltaPace77's Avatar
Really doubt you're gonna find a compressor with the labels on it, but as mentioned can try repros, or even transfer the old labels with a little heat. The shaft seals on A6's are real leakers, and probably good going with something else. Curious where the compressor hp ratings are coming from, as most car A/C's are less than 2 tons(typical 3 bedroom ranch home 2-3 tons), at about 1 hp per ton capacity. It usually takes about 20 hp to keep a car cruising at highway speeds, so somethings not right here.
Old May 14, 2012 | 02:41 AM
Aron Nance's Avatar
DeltaPace: What I meant to say is that when the A6 compressor "kicks in/turns on" there is an immediate feeling of how hard the car engine is turning/working (actual decrease in RPM?) with a noticable "lack of power", thus the approximation of losing 25 HP when the A6 is engaged. Do not mean to imply that the A6 is a 25 HP motor, at all. The Sanden unit should hardly be noticable when it engages.
Old May 15, 2012 | 12:54 AM
MaxDog's Avatar
I went ahead and purchased a remanufactured stock GM A6 compressor from YearOne for $199. Looks dead on with the original, except the stickers of course.
Old May 15, 2012 | 05:53 AM
Good idea when putting things back together, to give the system a UV trace dye shot. Easiest way to find system leaks later, by just scanning around with a UV light source.
Old May 15, 2012 | 06:43 AM
dc2x4drvr's Avatar
Classic Auto Air, reman's A-6 compressors the right way.(I've had problems with rebuilds from 2 of the larger rebuilders)..and they sell the compressor Aaron is referring to, which is a "plug n play" for our cars, and does save a ton of HP..
Nailhead 88
Jun 22, 2009 01:59 PM
1FSTLS1
Mar 4, 2008 06:45 AM
1FSTLS1
Dec 28, 2007 07:45 PM
2 door cut
May 14, 2007 07:52 AM
jaco
Jan 5, 2007 08:57 PM
