A/C compressor
A/C compressor
Anyone using or know anything about the newer aluminum compressors designed to replace the A6. I think its a 10 piston design?
I need a compressor, just trying to find out which would be the best choice
Steve
Steve
Going with the Sanden means you wont be able to use your factory brackets or hoses. The aluminum A6 replacement compressors are a bolt-in deal. Here are a couple of under hood kits I put together( one for a 70 Cutlass and the other for 67-72 gm truck) and a pic of one I installed in 70 c10
- A6 Pro6ten hiperformance 21 lbs lighter than stock (15lbs vs 36). Condensor – parallel flow 6mm
condenser {part #11-803P $280} w/6 rectangular tubes (like all new cars) vs. one round tube (stock)
from Classic auto air for 134 conversion Ron from CAA {866 294 9934 or 877 342 5526 x7022}
Receiver/Dryer # 12-202S $49, Hoses #13801 $349, POA valve – new w/core or rebuild current one
$100 to rebuild or $190 for new (w/$75 core refund), must use 42-48 oz of R134
Some good close ups of the compressor and the complete setup around 1:45 in this video:
Nailhead 88
Jun 22, 2009 01:59 PM
