Bumper Bracket Carriage Bolts problem/solution
Old Feb 25, 2021 | 07:15 AM
Jungle Cat's Avatar
I’ve noticed working on both Olds and Buick’s over the past several years there is a problem with replacement carriage head bolts offered in the aftermarket or hardware store. They are used on front and rear bumper brackets to frame for at least 70-72. I know some of the assembly plants used ordinary bolts instead. I like to use the carriage as that is what was used on the Michigan built cars I always work on.
The big problem is replacements from aftermarket sources have a much bigger square section under the head. This was the case with the last ones I ordered a few years ago and I’m not sure it’s changed? The bolt is meant for the square section to sit in the frame only to hold in place. The square section should not extend into the main bumper bracket at all. If the bigger square ones are used they lock the frame and bracket together and it does not allow up and down adjustability of the bumpers. It can be real frustrating if you don’t catch that. I suspect that’s why you see so many badly aligned bumpers at shows. I have resorted to getting out my grinder and cutting down the bigger square sections especially on the corners. This works fine but I prefer to use originals after having them phosphate plated. Originals can be tough to come by as you often have to cut them off. Anyone know if a source for correct ones? My guess is they have the big squares?
black is original. Silver are regular carriage bolts. I have found three different head types on originals. Three hash marks which identifies a grade 5 bolt. Also three hash marks and RWB manufacturer. And others with no marks at all.
Old Feb 25, 2021 | 07:33 AM
OLDSter Ralph's Avatar
"Carriage bolts" are standardized manufactured items. The black bolts you show are different, yes. They are specially made for auto manufacturers and for a special purpose. There is "someone" who has "specialty bolts" and fasteners for the auto industry. I am sure someone will chime in with a name.
You definitely want Grade 5 or better for bumper bolts.
Old Feb 25, 2021 | 07:44 AM
AMK has the factory-style bolts.
https://www.amkproducts.com/wp-conte.../BULK_6-24.pdf
Old Feb 25, 2021 | 07:46 AM
ROCKET VAPOR's Avatar
Lance
Old Feb 25, 2021 | 07:54 AM
Find a fastener store that carries auveco or dorman products. They are listed on ebay, amazon, etc...
Old Feb 25, 2021 | 08:33 AM
mrolds69's Avatar
Dave, I think I've bought Grade 5 bracket bolts at Tractor Supply before.
Old Feb 25, 2021 | 09:29 AM
Jungle Cat's Avatar
Hi Frank, the problem all the carriage bolts have the big square under the head and require grinding to allow the bumpers to be adjusted.
Old Feb 25, 2021 | 09:34 AM
Jungle Cat's Avatar
None of the AMK are correct. The stainless cap ones looks like they have small square but they are not correct for bracket bolts. The correct size is 7/16” by under head length 1 1/8”
Old Feb 27, 2021 | 11:14 AM
newmexguy's Avatar
Would try someone such as “azchevs” who parts a lot of southwestern cars. For originals. Am sure I have a few but most of the cars I took parts off in the early 00’s in the new mexico yards were Chevrolet.
Old Mar 1, 2021 | 06:37 AM
Jungle Cat's Avatar
Those are the animal. Nice shape too.
Old Mar 1, 2021 | 09:50 AM
Jungle Cat's Avatar
This is in lines offering. Note the big squares. These will not work properly unless you get the grinder out and knock down about half the squares. Clearly they never tried these.
https://www.inlinetube.com/products/...waAroYEALw_wcB
Cruiser Bob
Mar 1, 2021 03:11 PM
T.Wong
May 23, 2018 10:27 AM
Oldser 1
Jun 19, 2014 07:25 PM
Bunser
May 22, 2010 03:56 AM
tarheeldoc
Oct 23, 2007 11:01 AM
