Bulb Model for Dash Gauges?
Old Mar 10, 2014 | 03:49 PM
69ishHoliday's Avatar
I've acquired a speedometer with speed minder and Rally Pack for my car. What value lamp will work best for illumination and what source is easiest? I can't see performing the installation and not putting in new lamps.
Thank you, - Steven
Old Mar 10, 2014 | 03:53 PM
2blu442's Avatar
Hi Steven
Rob did a really nice job showing what he did to a set of gauges. Read through this thread and see if it answers your questions. John
https://classicoldsmobile.com/forums...-rp-stuff.html
Old Mar 10, 2014 | 04:08 PM
Answer appears to be 168
Originally Posted by 2blu442
Hi Steven
Great Thread Thank you!
Old Mar 10, 2014 | 05:04 PM
Magna86's Avatar
LED bulbs for the gauges and dash are a great cheap upgrade. Look online and find a distributor. Usually if you get them from overseas its alot cheaper than someone here in the states.
Old Mar 10, 2014 | 05:52 PM
Lady72nRob71's Avatar
Having a clean shiny paint job inside the gauge for the light to reflect off of is the most important thing. Try that with 168 bulbs and see the results before going the LED route - you just might be as impressed as I was!
Old Mar 10, 2014 | 06:13 PM
Thank you Rob for the detailed thread and results of the work on your gauges. I think I'm inclined to use the 168's and be done with it, although I have seen an impressive improvement in McIntosh Labs equipment illumination since they changed from regular bulbs to LED. If I experiment with the LED lamps I'll certainly share my experience. - Steven
Old Mar 10, 2014 | 06:20 PM
The concern I have with LED is that they use so little power that they will probably render the dimming function unusable. In home lighting systems LED bulbs don't function well with dimmers designed for incandescent bulbs. If anybody wants to respond with LED lamp experience on an A-Body I'd be interested in your findings. - Steven
Old Mar 10, 2014 | 09:37 PM
69ho aurora's Avatar
I faced the same dilemma almost a year ago. I thought my original style bulbs were too dim and started looking into LEDs. I bought a couple sets off of ebay and put them in. I'm VERY happy with the results. This gives you some indication of the difference. LED on the left with the standard bulb on the right.
They work fine with the dimmer. You just have to make sure you check that you insert them the right way as they are diodes. If they don't work, rotate 180 degrees and they will. I've got more than 10 left (I hadn't counted how many I needed and ordered 20). If you're interested, a couple bucks plus shipping and I can send you 10... Otherwise, I can try and track down which ones I ordered...
Al
Old Mar 10, 2014 | 09:58 PM
Hmmmmmm...
My gauges are annoyingly dim in my '73 Delta (a problem I never had in other GM cars I have owned), and I have had them apart, and the paint inside is nice and clean (I've cleaned everything thoroughly), and the paint is nice and bright, and I've also cleaned the fuse terminals, and replaced the headlight switch (for other reasons).
Perhaps LED lamps would be beneficial, especially if they can be dimmed (something I had been concerned about).
I would be grateful for any information about which LED lamps available on line are of good quality, as opposed to the ones that work for a week and then quit.
Thanks,
Old Mar 11, 2014 | 12:20 AM
nsnarsk65cutlass's Avatar
Al
I think the rh side is normal looking,as long as all the bulbs are lit i would not invest in led upgrades,imho.Nick
Old Mar 11, 2014 | 12:38 AM
Magna86's Avatar
I cleaned and repainted my housings before I went LED. They were brighter but the LEDs are night and day difference. Any bulb I can upgrade to LED in my Olds and my motorcycle clusters I will. Its like looking at modern gauges but with old school style.
Old Mar 11, 2014 | 03:58 PM
Al
Thank you Al, I'll take you up on your offer, I've sent you a PM. - Steven
Old Mar 11, 2014 | 08:41 PM
For anyone that is interested in using the same LEDs that I did, I tracked down who/what I bought on ebay. This is a current listing for the same part from the same vendor: http://www.ebay.com/itm/10x-T10-5SMD...item417d9c5339
Old Mar 11, 2014 | 11:46 PM
BILL DEMMER's Avatar
Just the facts...
now if they only offered them in bright orange...
bill
Old Mar 11, 2014 | 11:54 PM
Nop's Avatar
Nop
2-stroke 1-cylinder guy
Use orange silicone bulb cap condoms?
Example: http://www.ebay.com/itm/LOT-T10-194-...-/271417004693
Old Mar 12, 2014 | 02:28 AM
66-3X2 442's Avatar
How do the LED bulbs work in the turn signal indicators? I've heard they don't react quick enough to be brighter than the regular bulbs. Just asking because that's what I have been told by somebody that tried them.
Old Mar 12, 2014 | 06:33 AM
RandyS's Avatar
That shouldn't be a problem. LED bulb reaction time is MUCH faster than an incan bulb. The problem they can cause for turn signals is when they are used on the exterior lighting, as they don't draw enough current to properly operate the flasher.
Old Mar 12, 2014 | 10:53 AM
Just the facts...
replace the flasher with one that isn't dependent on the load, but you will lose the "bulb out" feature.
bill
Old Mar 12, 2014 | 07:52 PM
I didn't use any on the exterior. I tried them in the side marker "rocket" lights since it is the same type, but it didn't look right as you can see the filament on the original and the multiple individual LEDs on these assemblies and they don't look anything the same. Since I want a factory appearance, I would only use the LEDs for indirect lighting like the instruments.
a1970442
Jan 30, 2015 09:26 AM
Gitso
Jan 5, 2015 05:14 AM
KZ442
Nov 16, 2014 05:59 AM
nj_cutlass72
Mar 4, 2012 08:53 AM
citcapp
Dec 14, 2009 11:10 AM
