Bulb Model for Dash Gauges?
I've acquired a speedometer with speed minder and Rally Pack for my car. What value lamp will work best for illumination and what source is easiest? I can't see performing the installation and not putting in new lamps.
Thank you, - Steven
Thank you, - Steven
Hi Steven
Rob did a really nice job showing what he did to a set of gauges. Read through this thread and see if it answers your questions. John
https://classicoldsmobile.com/forums...-rp-stuff.html
Answer appears to be 168
Hi Steven
Great Thread Thank you!
Having a clean shiny paint job inside the gauge for the light to reflect off of is the most important thing. Try that with 168 bulbs and see the results before going the LED route - you just might be as impressed as I was!
Thank you Rob for the detailed thread and results of the work on your gauges. I think I'm inclined to use the 168's and be done with it, although I have seen an impressive improvement in McIntosh Labs equipment illumination since they changed from regular bulbs to LED. If I experiment with the LED lamps I'll certainly share my experience. - Steven
The concern I have with LED is that they use so little power that they will probably render the dimming function unusable. In home lighting systems LED bulbs don't function well with dimmers designed for incandescent bulbs. If anybody wants to respond with LED lamp experience on an A-Body I'd be interested in your findings. - Steven
They work fine with the dimmer. You just have to make sure you check that you insert them the right way as they are diodes. If they don't work, rotate 180 degrees and they will. I've got more than 10 left (I hadn't counted how many I needed and ordered 20). If you're interested, a couple bucks plus shipping and I can send you 10... Otherwise, I can try and track down which ones I ordered...
Al
Hmmmmmm...
My gauges are annoyingly dim in my '73 Delta (a problem I never had in other GM cars I have owned), and I have had them apart, and the paint inside is nice and clean (I've cleaned everything thoroughly), and the paint is nice and bright, and I've also cleaned the fuse terminals, and replaced the headlight switch (for other reasons).
Perhaps LED lamps would be beneficial, especially if they can be dimmed (something I had been concerned about).
I would be grateful for any information about which LED lamps available on line are of good quality, as opposed to the ones that work for a week and then quit.
Thanks,
Thanks,
I faced the same dilemma almost a year ago. I thought my original style bulbs were too dim and started looking into LEDs. I bought a couple sets off of ebay and put them in. I'm VERY happy with the results. This gives you some indication of the difference. LED on the left with the standard bulb on the right.
Al
Al
I cleaned and repainted my housings before I went LED. They were brighter but the LEDs are night and day difference. Any bulb I can upgrade to LED in my Olds and my motorcycle clusters I will. Its like looking at modern gauges but with old school style.
Al
Al
For anyone that is interested in using the same LEDs that I did, I tracked down who/what I bought on ebay. This is a current listing for the same part from the same vendor: http://www.ebay.com/itm/10x-T10-5SMD...item417d9c5339
Use orange silicone bulb cap condoms?
Example: http://www.ebay.com/itm/LOT-T10-194-...-/271417004693
How do the LED bulbs work in the turn signal indicators? I've heard they don't react quick enough to be brighter than the regular bulbs. Just asking because that's what I have been told by somebody that tried them.
That shouldn't be a problem. LED bulb reaction time is MUCH faster than an incan bulb. The problem they can cause for turn signals is when they are used on the exterior lighting, as they don't draw enough current to properly operate the flasher.
bill
I didn't use any on the exterior. I tried them in the side marker "rocket" lights since it is the same type, but it didn't look right as you can see the filament on the original and the multiple individual LEDs on these assemblies and they don't look anything the same. Since I want a factory appearance, I would only use the LEDs for indirect lighting like the instruments.
