Brakes
Old Jul 22, 2013 | 02:33 PM
Guy Fillinger's Avatar
Brakes
Hey guys i've got a problem got a 69 442 and I've got very little brakes what little I do have seems to be from the rear pedal goes to the floor and have to pump pedal twice to to get that Ive changed the Master cylinder and the front calipers and still got the same problem(rear brakes are ajusted properly) I do have a metering valve off the front port and also a pressure differential valve on the frame. (I think thats what you call it) I'm going broke changeing parts got any ideas?
Guy
Old Jul 22, 2013 | 02:42 PM
Guy
Back up. Do you have front discs or drums? When you say metering valve, do you mean the stock style for 67-70 that mounts under the M/C? When you say "pressure differential valve on the frame" do you mean a distribution block or a combination valve?
Old Jul 22, 2013 | 02:53 PM
brakes
Thanks foe responding It has front disc brakes. I has a small round valce mounted on booster next to MC The valve on the frame must be a disstribution pressure switch combo. Its got a wire going to middle of for the brake light
Old Jul 22, 2013 | 03:01 PM
hookem horns's Avatar
Have to ask the obvious, but did you bench bleed the MC before installing and then bleed all 4 wheels?
Old Jul 22, 2013 | 03:02 PM
Guy,
Does the block on the frame look like this:
Or like this:
The first one is the correct distribution block to go with your metering valve. If that's what you have, your parts are correct. You just still have air in the system and need to keep bleeding.
The second one is a combo valve that should not be used with the metering valve.
Old Jul 22, 2013 | 03:11 PM
Brakes
Yes I did bench blead the MC and I will go back and bleed the system some more and I will let you know.
Thanks Guy
Joe
I have the first valve you showed in the pics
Old Jul 22, 2013 | 03:51 PM
WTony's Avatar
Did you change the front calipers and are the bleeders on the top of them, not facing downward? If they are facing down they're on the wrong sides and you'll never get the air out of the system.
Old Aug 15, 2013 | 10:22 AM
Brakes
Its been awhile since I posted my problem, but I want to give everyone an update. What I found to be the problem was the HOLDBACK VALVE it was the only thing I did not look at. Its mounted on the Brake booster next to the M C. I changed it out and the problem was gone. I don't quite understand why it would cause me to not have front brakes AND NO PEDAL but it did. I want to thank Joe and WTony for the advice.
Guy
Old Aug 17, 2013 | 03:00 PM
WTony's Avatar
Guy
Glad to hear you got it figured out. Now get that Olds out and enjoy a nice weekend cruise.
Old Aug 17, 2013 | 07:58 PM
pogo69's Avatar
morgan
I had the same problem with my valve it had a weepy drip on the back side of the valve from the rubber cup
Old Aug 19, 2013 | 09:23 AM
Brakes
Well it sure had me pulling my hair out and I can't aford to loose much more. Hopefully this info will help someone out in the future.
Guy
72allblackcoupe
Apr 6, 2014 07:20 PM
1carsick
Brakes/Hydraulic Systems
23
Oct 2, 2012 05:50 PM
russell-t
Apr 30, 2011 05:56 AM
Gtimmons
Cars Wanted
Sep 30, 2006 06:34 PM
Supreme
Aug 11, 2004 06:58 PM
