Brake Proportioning Valve
Old Apr 9, 2012 | 12:09 PM
Curts1970cutlass's Avatar
Will the non power Drum prop valve, and the Power Drum prop valve be the same on a 72 cutlass?? Not sure if the valve is just different for disc/drum set ups. May just be one less thing I have to take off.
Old Apr 9, 2012 | 03:39 PM
Four wheel drum brake systems do not use proportioning valves. They have a distribution block that simply houses the differential pressure valve that illuminates the BRAKE light on the dash if one side of the system looses pressure. There is no front/back proportioning at all. The distribution block is identical for power and non-power brakes.
oldspackrat
Oct 29, 2017 07:38 PM
Mike H.
Brakes/Hydraulic Systems
Mar 7, 2013 10:48 AM
zodiacblueS
Jan 4, 2013 09:45 AM
GStage1
Apr 11, 2012 11:39 AM
Chumley
Feb 2, 2008 04:35 PM
