Brake pedal slow returning
Hi all,
Bled the lines with a mitivac. When I press the brake pedal, it takes a while to come back up.
'62 88, drums all around, single master cylinder, power brakes. The booster is not new - but the pedal is sinking a bit when the car is started, which makes me think there's some vacuum.
Any ideas what this could be?
No ideas, huh?
This is pretty maddening. Bled the brakes twice, bench bled the MC twice. Still need to wait 20 sec after flooring the brake pedal til it comes back up again.
Weird. Guess I'll ask the HAMBers if there are no suggestions here.
I'll throw one idea out there..I don't know if this will stick. This sounds like a master cylinder problem, but for some reason I think brake hoses up front, debris in the system or poor hoses.
I've never worked on anything like your model. Hope you find a solution.
This could be but when ever this type problem occurs usually you have a stuck brake at the same time. Left a lone it will after a time free up as the pressure drops off. Is the brake drum (wheel) sticking?....Tedd
I haven't been driving this car though, as there is no exhaust - typically I work on it late in the evening and don't want to drive my neighbors nuts. I really need to get an exhaust on it
- MC is rebuilt but has been sitting around.
- distribution block is old
- I made all new brake lines
- brake bits (springs etc) in the drums are new
thanks
Justin
A bad booster wouldn't make it return slower, something is causing the fluid to not have enough pressure. Plus if it were the booster leaking you'd know it in other ways by the engine running really lean. Either there's a leak somewhere or air in the lines would be my guess.
EDIT: I forgot to ask, in this car do the drums have their own cylinders in addition to the master cylinder?
Not to hijack my own post...(but I will)
Can anyone suggest a replacement brake booster / dual circuit MC combo that would be relatively easy to adapt to this car ('62 olds 88)?
I'm not concerned about 'correctness' or originality.
It's kind of a Might-As-Well, but I guess it makes sense safety-wise for me to consider upgrading to a dual MC.
I'd suggest making sure the MC is actually the problem before spending money on it. Evidently based on what I've been reading toymobile might be right, it could also be the booster.
Good luck.
Johnny
Very often, the old leaky master cylinder will have been leaking brake fluid
into the booster. I think you will find brake fluid, and rust in the power booster, even if it is still sort of working.
