Brake booster
Brake booster
I have a 1970 Olds 442 with a manual transmission. Mine has a brake booster on it, that is about 1 inch from the valve covers . Every where I look a manual transmission doesn't have a brake booster .Could someone let me know what's correct and why the booster is so close to the valve covers .
The booster is close because it is a big engine jammed into the same compartment as a normal engine. Love your big engine, and it will love you back.
Manual transmissions are not the same thing as manual brakes. Independent systems. The booster is a vacuum assist for the brakes to help you hammer on them. It does not know, nor care, how the power gets to the wheels through the transmission. The reason manual trans cars often have manual brakes is because both options are cheaper, and are more "race car" oriented. A family man will want an automatic transmission power brake high option car; James Dean will want manual everything.
Factory big block cars came with valve covers that were notched to provide additional clearance to the booster (and the HVAC box). Aftermarket tall valve covers don't clear. I'm not sure why you're worried about an inch or so of clearance - if the engine moves that much you have a broken motor mount.
zodiacblueS
Brakes/Hydraulic Systems
44
Oct 12, 2014 03:22 PM
plasma98
Apr 20, 2007 12:06 PM
