brackets!!
Welcome to the group... First question that comes to mind is if you are using a 77 350 why not just use 77 350 alternator brackets, which should be rather easy to find... There are different style 350 brackets based on various applications, therefore the brackets best suited for your 350 could be determined by your actual project and alternator location (left or right side of engine)...
With or without A/C? FYI, any 1964-1990 SBO brackets will bolt to that motor. You just need to use all of them, along with the matching water pump and pulleys, as a matched set.
olddaz
August 27th, 2014 06:39 PM
