brackets!!
Old Oct 23, 2017 | 01:38 PM
toolman's Avatar
Smile brackets!!
I am using an 1977 olds rocket 350 on a project, but I need alternator brackets. not sure where to go to find them or what part numbers to use. any help would be greatly appreciated!!
Old Oct 23, 2017 | 03:19 PM
CRUZN 66's Avatar
Olds Fever
Welcome to the group... First question that comes to mind is if you are using a 77 350 why not just use 77 350 alternator brackets, which should be rather easy to find... There are different style 350 brackets based on various applications, therefore the brackets best suited for your 350 could be determined by your actual project and alternator location (left or right side of engine)...
Old Oct 23, 2017 | 04:45 PM
With or without A/C? FYI, any 1964-1990 SBO brackets will bolt to that motor. You just need to use all of them, along with the matching water pump and pulleys, as a matched set.
olddaz
Aug 27, 2014 06:39 PM
ERIC27
Mar 3, 2013 11:14 AM
HWYSTR455
Aug 30, 2006 04:40 AM
TOONLOVESCHERYL
Jul 4, 2006 08:07 AM
