Bolt size
Oh. Project bolt bin. Not car parts. This is a a small hardware store stocked occasionally. I did have to go with socket head cap screws, the hex heads weren't small enough. Did get standard though, we have both.
Our cars are put together with 7, 10, 14, and 18 mm bolts and screws, I think.
Dave, that is a 1/4 inch bolt long enough to go thru the plastic and the little sleeve and the fender, also use a washer behind the bolt and the plastic tank or it will split, also dont tighten it super tight, it's been a while but I think its 1 1/4 inch long, Tim
Would this be the same type of fastener as is used to attach the window washer reservoir to the inner fender? If so, a description of that screw would be 1/4 hex head - 14 X 5/8" long with a built in washer and an outside diameter of 1/2" in a gray-black finish. Just a stab in the dark just in case!
Randy C.
Randy C.
Kyle's77cutlass
Drivetrain/Differentials
15
Feb 24, 2020 05:44 PM
