Bolt size
Old Oct 6, 2020 | 05:30 PM
72455's Avatar
1972 U code Supreme
Bolt size
Anyone know what length/size bolt I would need to bolt the coolant reservoir to the fender on my '72 Supreme?
Thanks,
Dave
Old Oct 6, 2020 | 06:10 PM
Yeah, I'm about to do it myself. What one do you have?
Old Oct 6, 2020 | 06:21 PM
72455's Avatar
1972 U code Supreme
This one...got the complete kit from OPGI for 116 and some change...
Old Oct 6, 2020 | 07:16 PM
You'd think for that amount of money they would provide the less-than-one-dollar set of screws to go with it.
Old Oct 6, 2020 | 08:35 PM
72455's Avatar
1972 U code Supreme
Check Fusick and Parts Place...they're double that.
Old Oct 6, 2020 | 10:22 PM
I raided my bolt bin at work. I'll post what happens.
Old Oct 7, 2020 | 07:04 AM
RetroRanger's Avatar
72 Olds CS
metric? Theyre all going to laugh at you!
Old Oct 7, 2020 | 07:51 AM
Why would I use metric?
Old Oct 7, 2020 | 09:30 AM
72 Olds CS
in the past youve mentioned your employer is a japenese car manufacturer. Those cars typically use force fit SAE fasteners or metric ones. My guess is your parts bolt bin at work is filled w metric fasteners. .
Old Oct 7, 2020 | 10:51 AM
Oh. Project bolt bin. Not car parts. This is a a small hardware store stocked occasionally. I did have to go with socket head cap screws, the hex heads weren't small enough. Did get standard though, we have both.
Our cars are put together with 7, 10, 14, and 18 mm bolts and screws, I think.
Old Oct 7, 2020 | 11:00 AM
green1972's Avatar
Dave, that is a 1/4 inch bolt long enough to go thru the plastic and the little sleeve and the fender, also use a washer behind the bolt and the plastic tank or it will split, also dont tighten it super tight, it's been a while but I think its 1 1/4 inch long, Tim
Old Oct 7, 2020 | 12:38 PM
rcorrigan5's Avatar
Randy C.
Would this be the same type of fastener as is used to attach the window washer reservoir to the inner fender? If so, a description of that screw would be 1/4 hex head - 14 X 5/8" long with a built in washer and an outside diameter of 1/2" in a gray-black finish. Just a stab in the dark just in case!
Randy C.
Old Oct 7, 2020 | 07:07 PM
72455's Avatar
1972 U code Supreme
Thanks for all the replies...I ended up using a 5/16-18 x 1-1/12 inches long.
tkcutlass
Jul 10, 2020 08:32 PM
Kyle's77cutlass
Drivetrain/Differentials
15
Feb 24, 2020 05:44 PM
Josh Robb
Sep 24, 2019 11:07 AM
PM70
Apr 15, 2017 01:17 PM
