bodywork i have done**non Olds**
Old January 11th, 2011, 09:47 PM
85_Cutlass_Sedan's Avatar
Smile bodywork i have done**non Olds**
i am new to the site... thought i would post this here since it isnt an Olds and i dont have privileges to the rest of the site to post... below are pics of a car i did work on and a scheme i wanna somewhat put on my fiance and myselfs 1985 Olds Cutlass Supreme Sedan... i am thinking of doing a metallic pea green body with a darker emerald green stripe with silver marble sprayed with a candy green on marble...
85_Cutlass_Sedan is offline
Old January 12th, 2011, 05:20 AM
Lady72nRob71's Avatar
Nice color choice - swell job on applying it!
How in the heck did you do the marbled look? I saw that done with powdercoat but not paint...
Lady72nRob71 is offline
Old January 12th, 2011, 05:25 AM
olds425's Avatar
Very nice! Welcome to the site.
olds425 is offline
Old January 12th, 2011, 05:27 AM
Past Administrator
Oldsguy's Avatar
Nice work. Was going to ask the same question about the marbled look on the paint. I have seen lace work done before, similar?
Oldsguy is offline
Old January 12th, 2011, 05:36 AM
W70442's Avatar
I'm sure he'll answer but I think you spray the color wet and then lay thin plastic sheeting on the paint, maybe move it around some, and then remove it leaving the messed up/marbled look.
W70442 is offline
Old January 12th, 2011, 10:28 AM
the marble look was done by doing all the bodywork on the car and getting it primed, then block sanded numerous times...
i then figured out where i wanted the stripe and sanded it
i layed down a base of color of what the rest of the car was gonna be
then the stripe was masked out and shot with marbelizing paint in a kind of light coat
then here is the trick, lay on some saran wrap after the marbelizer set for a couple minutes with a partner and get it to stick to the marbelizer
peel the saran wrap off and reapply marbelizer again and saran wrap...
the saran wrap needs to be pulled at a 90 degree angle carefully and depending on which way you pull you see the effect.
let the marbelizer set for 15 minutes then hit it with candy transparent red
i let the stripe set for the night then fine sanded and masked and papered the stripe
then i painted the car and removed the mask over the strip and followed that by clear
Old January 12th, 2011, 01:24 PM
Past Administrator
Oldsguy's Avatar
Cool. Any reason the owner only wanted a stripe done that way instead of the whole car?
Oldsguy is offline
Old January 12th, 2011, 03:21 PM
it was my design of the car... it belongs to my ex and now wish i never did the work for her while we were together
Old January 12th, 2011, 04:21 PM
nukesec1's Avatar
So Cool! Saran wrap keeps food fresh AND it makes cars look awesome! I so love this technique!
nukesec1 is offline
Charly9g
Body work
January 28th, 2013 07:00 PM
Ranzan
Body work
March 24th, 2012 06:11 PM
72cutlassolds
February 5th, 2012 07:58 PM
Ranzan
December 5th, 2010 04:53 PM
2blu442
Body work
February 6th, 2009 04:36 PM
Quick Reply: bodywork i have done**non Olds**
