Block to head pins
Old May 2, 2019 | 10:20 AM
Chuck Cole's Avatar
Oldscarnut
Block to head pins
While putting in the cam and crank, in the bottom of the box of mains, I found 4 pins. I was surprised to find them, but I think the machine shop decided to do nothing more than their work since I was trying to save about a grand, building the engine myself. I have built 4 previous engines in the 90's all of which are still running fine. However, I have never installed the pins before and I can find no mention of them in the books and YouTube vids. I think I should just carefully tap them in, but I would appreciate any advice as to lube or seal or other things I should or should not use. Since there are 4, I cannot see another place other than the block to align the heads. I'm still awaiting my ring and piston installation tools They were retired years ago in a yard sale. Who knew at age 67 I would build another?
Old May 2, 2019 | 11:26 AM
don71's Avatar
same but different
Are you referring to cylinder head alignment dowels? There many videos on removal, I did not see any referencing installation.
Make sure the pins and holes are clean and free of rust and defects and are nice and smooth. Simply tap them in with a little oil for lube and leave them proud about 3/16''-1/4''.
Old May 2, 2019 | 11:30 AM
boese1978's Avatar
I lightly tapped mine in to 1/2 the length of the pin / dowel, worked out fine. I did not use any lube on my pins.
Old May 2, 2019 | 02:11 PM
Chuck Cole's Avatar
Oldscarnut
Seems easy enough! Thanks...just didn't want to make any mistakes,
Old May 2, 2019 | 02:12 PM
Chuck Cole's Avatar
Oldscarnut
Thank you. They are super smooth now so I think they need to go in!
edzolz
Sep 22, 2017 08:25 AM
tinner
Mar 16, 2015 10:09 PM
oldzy
Oct 12, 2011 06:50 AM
smcurro
Dec 20, 2010 02:03 PM
Bobsw32
Apr 15, 2009 05:00 PM
