Big Block Olds In Cheby A Body
Old Apr 28, 2017 | 07:18 AM
78 omega 468's Avatar
I have found a Cutlass front cap for my 67 El Camino. I want to put a built 468 Olds I have in the shop in it. I see that the battery will have to be moved and the starter wiring extended to the other side. Is there other differences that anyone can tell me in advance?
Old Apr 28, 2017 | 07:50 AM
CRUZN 66's Avatar
Olds Fever
What is a "Cutlass front cap" ??
Old Apr 28, 2017 | 08:12 AM
Everything from the doors forward, fenders, hood, grille & bumper. To make it look like a Olds El Camino, I even saw a 76 a guy had put at Pontiac Grand Lemans front cap on. Doors, cowl etc are almost identical. The share the same frame etc.
Old Apr 28, 2017 | 08:17 AM
toymobile's Avatar
Need A body Olds motor mounts and BOP trans, Everything else will be just a matter of GETTING HER DONE.
Johnny
Old Apr 28, 2017 | 08:23 AM
Thanks toymobile, I was thinking the same but wanted to hear from others.
Old Apr 28, 2017 | 08:59 AM
If you mean that you have a complete front end, be aware that NONE of the body lines are common. The Olds fenders will not match the Chevy doors. As for motor mounts, get the same year range Olds frame and motor mounts. The A-body frames are drilled for every division's frame mounts.
Old Apr 28, 2017 | 09:06 AM
edzolz's Avatar
I've seen this done with nearly every year A body. Most of the time you need to use the matching doors and do some sheet metal work to match everything up. Or you could do what an NTOC member did with a 70 GMC Sprint and make it into an Oldscamino. Used to be on a members site here. Might google search for it
Old Apr 28, 2017 | 09:22 AM
edzolz's Avatar
Go to the Texas442.com website and in the left side column, there is a link to "not an elcamino" to see the 70 I told about in the above post.
bocoogto
Aug 26, 2023 06:09 PM
jensenracing77
Apr 28, 2017 06:32 PM
bspaulding
Sep 3, 2016 04:15 PM
Octania
Apr 7, 2016 02:51 PM
jensenracing77
May 29, 2015 01:20 PM
