Best Timing Light?
Old May 19, 2013 | 05:03 PM
KDV's Avatar
KDV
Best Timing Light?
My inductive timing light has gone to that big timing mark in the sky.
I'd like to replace it with a better quality one - any suggestions?
Old May 19, 2013 | 05:27 PM
Sure, but they're not inspired.
1. Open 'er up and check the wires where they enter the case - you'll often find one broken.
Easy fix.
2. I've gotten all mine at yard sales and flea markets. I can't recommend one that's worth fifty or a hundred dollars when I get them for five or ten.
Old May 19, 2013 | 05:40 PM
Get one that has a setback dial and is compatible with a MSD if you have one.
Old May 19, 2013 | 05:50 PM
OmegaClassic's Avatar
SETBACK for sure,since "tabs" only go to +14 degrees.
Total ,with mech advance,around 24 deg,
Also, does anybody out there know if it's okay to bypass the heater core ?
ie Connect Inlet hose to Outlet hose?
Original heat control was by opening/closing doors. Coolant flow ALWAYS thru core,even during our 95to100degF summers here in Louisiana.
Old May 19, 2013 | 06:25 PM
Sure. Either shunt it back to the other side, or, even easier, install a valve and just shut it.
You can get hose-barb valves you can turn closed at NAPA, among other places, or get a vacuum-operated valve from an A/C car and run a switchable vacuum line to it, so you can turn it on and off at will.
Old May 20, 2013 | 12:54 PM
Heater bypass
Thanks for reply ,MD.
I was concerned that either solution would change ORIGINAL DESIGN for flow pattern and may create hot spots
The shunt ( what i called bypass) will have much less resistance than the heater core. Coolant will then take path of least resistance thru bypass to water pump suction,resulting is less flow thru heads &manifold.
And a shutoff ,not part of original heater controls, will force too much coolant thru heads &manifold on wayto thermostat & radiator. Higher velocities may not cool as well.he Engine is best part of the Olds and i hate to mess it up. It survived 40years sofa!
Old May 20, 2013 | 01:10 PM
You're over thinking it.
A bypass will behave exactly the same way as the original flow through the heater core did.
A valve replicates the original system in A/C cars.
There may be some critical components on these engines, but this ain't one.
Old May 20, 2013 | 01:35 PM
KDV's Avatar
KDV
Thanks for all the input
My current light has an abs plastic housing that I would bust all to hell trying to get apart - I've tried. May just cut the wires off of it and let the kids play with it
So I've ordered a dial back light with a die-cast aluminum housing with the hope that should I need to - I can take it apart and re-assemble it.
Old May 20, 2013 | 01:43 PM
Bypass
ok,then the previous owner must have tinkered with it..
My Omega HAS original A/C evap, POA valve,accumulator cond & all with compressor missing when i purchased it.Will fix later.
Heater hoses have a mysterious pipe coupling which must have been where the shutoff valve was.
So what's better a bypass or shutoff? I don't want heat in summer,even with the "doors"closed.Thanks.
Old May 20, 2013 | 03:18 PM
Half of one, six dozen of the other, really.
No difference.
Seems easier to me to put in a valve, but if you like the other way, that's good, too.
Old May 20, 2013 | 04:51 PM
BlackGold's Avatar
I wouldn't trust the markings on the cheesy plastic **** of a 10% accurate potentiometer on a timing gun made in China -- unless I calibrated it first.
If you a scribe mark for 30 degrees on your balancer, you can just use a simple, no-dialback gun. Saves money, and it's more accuracte.
Old May 20, 2013 | 06:41 PM
Or just use my handy Oldsmobile timing tape.
The site will compress it to the point of unusability, but if you e-mail me, I can send you a clear copy that should print the right size.
gmsteve455
Apr 8, 2014 08:44 AM
jpc647
Jun 10, 2013 11:48 AM
scooter123
Apr 6, 2012 01:34 PM
442scotty
May 13, 2009 05:42 PM
dingusboy
Apr 2, 2009 02:56 AM
