Back up lights not working
Old Jul 1, 2017 | 05:21 AM
PM70's Avatar
70 CS - neither back up light works. Could it be one bad bulb, both, or a fuse? And where are the fuses for these? I couldn't find them. Thank you!
Old Jul 1, 2017 | 06:26 AM
Yes, there is a 20A fuse marked Dir Signal/Back up. Did you check the voltage at the light sockets?
Old Jul 1, 2017 | 06:28 AM
PM70's Avatar
Not yet. Where is the first located? Thanks.
Old Jul 1, 2017 | 06:39 AM
Second one from the bottom on the right side.
Old Jul 1, 2017 | 08:09 AM
PM70's Avatar
Thanks.
Old Jul 1, 2017 | 11:55 AM
Does your neutral safety/backup light switch work? Have you tried unplugging the two wire connector with the green wires from the backup light switch and jumpering across the terminals in the connector to see if the lights come on? Has this car been converted to floor shift from an original column shift car?
cbogartjr
Aug 3, 2008 06:18 AM
silverriff
Feb 13, 2008 03:59 PM
black betty
Dec 21, 2007 12:13 AM
Calvin.Norris
Nov 27, 2007 06:08 PM
<KEN>
Sep 22, 2004 08:39 PM
