Back seatrest removal on 68 convertible
Old Sep 27, 2024 | 06:46 AM
AK Cutlass's Avatar
I am new to this car and forum so bear with me. I'm trying to remove the seat backrest on my 68 convertible and I don't want to break or tear anything. The seat bottom was easy and conventional but how do I take off the back? Are there bolts or clips that need to be accessed from the trunk? Or do I just jerk up on on it and release it from some kind of clips? I'm afraid that the shop manual is not much help.
Old Sep 27, 2024 | 06:50 AM
Hang tight. I'll see if I can find you an illustration/diagram of the clips. Removal is from inside the passenger compartment.
Old Sep 27, 2024 | 07:08 AM
Either d/l the image to zoom or use your Browser to zoom to gain better visualization. I'll grab you some dialogue to assist.
Old Sep 27, 2024 | 07:12 AM
Hope this helps...
Old Sep 27, 2024 | 07:58 AM
AK Cutlass's Avatar
Thanks Chief, just what I needed. Where did you find that?
Old Sep 27, 2024 | 08:24 AM
Fisher Body Service Manual
Old Sep 27, 2024 | 08:32 AM
To be honest w/ you, I pulled that image from my 1971 Oldsmobile Body By Fisher Service Manual. Since I've owned a 1967 4-4-2, 1971 4-4-2 & 1971 CS convertible best I recall all were nearly same if not identical. The image I provided you should be identical or similar between the 1968-1972 model years. It would help you to own an original OEM edition for your 1968.
1968 Body By Fisher Service Manual Used Condition
Old Sep 27, 2024 | 09:18 AM
ben442's Avatar
Two bolts to remove at the bottom of the seat back. Get down low and you can see them, then lift the seat back straight up to remove.
Old Sep 27, 2024 | 11:39 AM
AK Cutlass's Avatar
Thanks for the tips. Just ordered the Fisher body manual and already have the shop manual and factory assembly manual. I also have a parts manual coming. Anything else I need?
Old Sep 27, 2024 | 11:40 AM
AK Cutlass's Avatar
Just bought it.
jamba
Sep 20, 2023 05:53 AM
lshlsh2
Mar 2, 2023 07:09 AM
Bfg
Apr 4, 2015 06:59 PM
shamusj
Aug 13, 2013 10:29 PM
raider973
Oct 7, 2012 10:57 AM
