B body spindles on a big block?
Old Oct 21, 2011 | 05:58 PM
rogiestone's Avatar
Has anyone out there installed B body spindles on a 72 big block ? I have read that there might be issues with the alignment shims on a big block.
Old Oct 21, 2011 | 07:02 PM
Big block = Engine
B-body = Chassis
Spindles = Suspension parts, that attach to chassis, not engine.
Old Oct 22, 2011 | 11:09 PM
rogiestone's Avatar
Originally Posted by MDchanic
Big block = Engine
B-body = Chassis
taller B body spindles = more control arm shims
more control arm shims = possible interference with exhaust
so therefore all things should be considered when changing suspension parts even the engine which mdchanic is right dose not attach to the engine
Old Oct 23, 2011 | 09:27 AM
gearheads78's Avatar
car guy
....or don't run B body stuff and create new bump steer issues. If you want it to handle use tall ball joints or the right spindles. AFX that use C5 / C6 brakes or now L&H makes some now that will use stock brakes.
bocoogto
Aug 26, 2023 06:09 PM
Murco
Brakes/Hydraulic Systems
Mar 7, 2013 11:50 AM
rogiestone
Oct 18, 2011 06:11 PM
olds4life
Feb 9, 2010 08:48 AM
NEWOLDSMAN
Nov 17, 2009 12:19 PM
