Arm Rest Base to Door Screws
Hi all - I wanted to know if someone knew the size of the arm rest base to door screws for 72 Cultass vert. There are 3 screws that attach the base to the door. I know companies sell them, but it's unreasonable to purchase 6 screws for $10 when I can go to the local hardware store to grab them for $2.
Yeah they are special. Many times they're lost and someone tries to use big wood screws or whatever and then they pull out and screw up the sheet metal. I did have a bunch of them in a coffee can as Joe said but when I moved all that stuff went to scrap yard. Maybe someone else will have some. or you could go to a salvage yard and get some out of any 70's GM. Probably easiest to just buy them on line, especially if you need other things you can bundle with them to save on shipping...
Looking at the OPGI ad, they are just phillips head sheet metal screws that can be had at any bolt and fastener store. The screws are available in up to 3 and 4" lengths.
https://www.opgi.com/cutlass/PP0225/
https://www.fusickautomotiveproducts...s.asp?dept=768
$20 for the interior kit is cheap IMO. You know you will find other missing/incorrect fasteners.
Herbs has helped me out for singular items several times. They can sometimes go by application but they prefer to have the SAE size.
https://hardwareandfasteningsolutions.com/
davoaz
March 31st, 2015 06:40 PM
