Amps required for Aftermarket Water and Temp Gauges
I was working under my dash and I accidentally pulled a wire from one of the fuses in the fuse block that the previous owner had stuck in there. He placed an Auto Meter 3431 Water Temp and 3421 Oil Press Gauge under the dash. He then crimped both wires together into one wire with a metal connector at the end. He had then pushed that connector into one of the fuse blocks. I just can't remember which block and what amps the 2 together would require. I'm figuring the 2 together would need at most 10amps but I want to be sure. Kind of a hack job but it works for now until later. See attachments. Thanks
bill
Took everyone's suggestions and at the end of the day the gauges will work without any connections. However, the lights don't come on. I tried the lowest amp 4 on the fuse block...no light. Went to a 10amp and worked as expected with lights on. Used Bills suggestion to find the protected side as well. In all the confusion I didn't even think of trying the auto meter website so I'll give that a go.
Thanks everyone for the help and suggestions. Trying to separate fire from smoke as I learn
Emreozd
February 19th, 2012 06:27 AM
