Altenator Clean up
Old Mar 4, 2013 | 06:30 AM
m455sx's Avatar
Olds Nut
Talking Altenator Clean up
I am planning to get my Altenator fixed as the Red Wire in the back where it attaches is loose in the Assembly. I found a local guy that can repair and/or rebuild. He told me to clean it up before i bring it to him. The altenator is clean but i want to make it look new on the casing. I need to best way to clean it up.
Old Mar 4, 2013 | 06:57 AM
Disassemble the alternator and have the case glass beaded. Shoot flat clear over it if you want to preserve it.
Old Mar 4, 2013 | 07:00 AM
m455sx's Avatar
Olds Nut
Thanks Joe!! Now the hard part trying to find someone to do locally.
Old Mar 4, 2013 | 08:01 AM
stellar's Avatar
If you can't find someone local (which I recomend) I can do it all for you. Clean, blast, rebuild, and clear coat. That would mean shipping both ways. If you don't need a numbers matching alt, a local parts store should have one for you.
Old Mar 4, 2013 | 04:02 PM
pcard's Avatar
70 Cutlass SX
Mark (Stellar) does great work if you can't find someone local. IMHO it is worth the postage.
Old Mar 5, 2013 | 06:10 PM
stellar's Avatar
Thanks for the recomendation. If he get his mammary gland caught in a wringer I would be glad to help.
Old Mar 5, 2013 | 06:15 PM
stellar's Avatar
If you can't get it glass bead blasted, ( I would recomend a complete disassembly for this), You may try a soft wire wheel to spruce it up a bit.
Old Mar 6, 2013 | 03:01 PM
BlackGold's Avatar
Regardless of who you have rebuild it, emphasize over and over that you do NOT want them to paint the case. for some reason, rebuild shops think they're doing you a favor when they paint it. I've had this problem with an alternator and a transmission -- despite the fact I told them not to paint it. In each case they were so proud of the fact that they found a paint that "looks just like aluminum." Ummm, no.
Old Mar 6, 2013 | 03:16 PM
stellar's Avatar
I don't like painted aluminium either. I do like a good clear coat, but it should be a high temp non yellowing type. It will keep the finished look and clean up easy too. If you don't clear coat it, it will oxidize. Never paint or coat the inside and do not cover any part that will be used for a ground connection.
Old Mar 6, 2013 | 05:12 PM
TK-65's Avatar
Ken Bruno did this one
The Stickman
Mar 24, 2011 11:48 AM
charlierogers
Jan 26, 2011 07:59 AM
cisco88
May 27, 2008 03:12 PM
cisco88
Mar 26, 2008 05:01 AM
cisco88
Feb 29, 2008 01:32 PM
