aftermarket rally pack
These posts should help you, esp. the middle one.
https://classicoldsmobile.com/forums...tml#post130178
https://classicoldsmobile.com/forums...tml#post236324
https://classicoldsmobile.com/forums...tml#post133199
https://classicoldsmobile.com/forums...rmarket-rally-
gauges.html#post133199
My car had the ralley gauge but someone removed the tach and put a clock there. Since they only sell the repros as a pair, I bought those. They are very close to original on the face that you see once installed. The housings on mine were metal. The lettering is just (barely) slightly different and I also heard the tach needle is not exact (wider on the repro). However, mine worked and look well and I put in brighter 168 bulbs (versus 194) and it seems fine. I may do the painting upgrade previously mentioned but they don;t look bad as is with brighter bulbs. It is also possible the newer versions were upgraded with better painting by the Parts Place.
Many thanks!
