Additives in gasoline
Old Dec 12, 2025 | 01:26 PM
Bfg's Avatar
Bfg
I heard from a friend today that the oil companies are being forced to remove the sulfur from gasoline, don’t know if it’s true or just a rumor
Old Dec 12, 2025 | 02:24 PM
This has been an ongoing trend since 2000, sulfur in gas has no real benefit to combustion engines. The benefit is mostly in older diesel engines.
Old Dec 12, 2025 | 02:57 PM
VC455's Avatar
Barely Registered
As of Jan 01, 2017, sulfur in gasoline was required to be no more than 10 parts per million (down from 30 parts per million).
There have been no changes to sulfur requirements since then.
Old Dec 12, 2025 | 03:14 PM
I'm sorta taken back by the thread title "Additives in gasoline" & not sure what is/was meant by additives in gasoline. All crude oil on the planet is derived from living organisms which died millions of years ago. All living organisms on the planet contain sulfur. Maybe you're thinking (instead) - gasoline contaminants? They've been removing sulfur from crude oil since late 1920s early 1930s. Sulfur has never been an 'additive'.
Old Dec 12, 2025 | 03:48 PM
tru-blue 442's Avatar
Old School Olds
If anyone wants the real scoop on dino-juice. I'm not sure, but there has to be a few mixed in?
https://www.chartindustries.com/Arti...5-Other-Things
Old Dec 12, 2025 | 04:31 PM
Unfortunately, the article speaks nothing to sulfur. But that's cool - crude oil is a hydrocarbon - and more. As said, all living organisms contain sulfur. Sulfur exists (in living organisms) in the form of sulf-hydryl (-SH) "thiol" groups. In the greatest majority of plants/animals two -SH (thiol) groups are bonded together to form disulfide bonds. It is the formation of disulfide bonds which impart the physical & functional nature of chemical compounds (e.g. proteins) which supports life.
Old Dec 13, 2025 | 03:37 AM
As mentioned, the lower sulfur diesel is harsh on older diesels. Nothing that can't be cured with a little ATF in the fuel tank though.
Old Dec 13, 2025 | 05:21 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Yeah the Sulphur was cheap lubrication in diesel fuel. Just watching the Motor Oil Geek, Lake Speed Jr. He mentioned European oils are higher in calcium due to making oils for high Sulphur fuel markets. Calcium levels effect the need of ZDDP and other additives. Supposedly despite the ZDDP drop in VR1, thanks to reduced calcium, the new formula is just as good as the old formula. The newest SQ rated oil has even lower Sulphated Ash. For fuel, buy Top Tier fuel, it has meet higher specs vs run of the mill fuels.
Old Dec 13, 2025 | 08:17 AM
RWK's Avatar
RWK
Cool
Put your worn stock die cast zinc rockers back on and start increasing your zinc ppm
Lead and sulfur are lubricants, they are added to many steels in increase machinability and reduce tool wear, and as we all know to reduce wear on valve seats.
MudEye
Apr 22, 2021 06:44 PM
Gary M
Oct 18, 2015 09:32 PM
jpc647
May 4, 2013 10:58 AM
scooter123
Apr 27, 2013 04:57 PM
olds67
Dec 5, 2009 01:11 PM
