AC and power brakes with w-30 cam
Old Jun 3, 2009 | 11:17 AM
scrappie's Avatar
I have a 71 442 with ac and power brakes. If I were to rebuild the engine to w-30 specs would I have to get different pistons (compression)?
I know the 328 cam is unique to w-30 motors and if I installed this in my engine with G heads and power brakes and AC would I have a problem with anything?(ac & power brakes)
Old Jun 3, 2009 | 11:26 AM
wmachine's Avatar
Trying to remember member
The 328 cam was used on the '70 W-30 stick motor only. You do not want that with an auto trans, and with power brakes you won't be able to stop. (not enough vacuum for the power brakes). I think you'd have all you can use with the 409759 '71 W-30 cam, and you'd appreciate being able to stop.
Old Jun 3, 2009 | 11:34 AM
scrappie's Avatar
How about if I went with the 294 degree cam (71 w-30) and stayed automatic?
How about if I went with the 294 degree cam and converted to a 4spd. and kept all accessories?
Would I still be able to run ac and have power brakes.
I guess I am confused because correct me if I am wrong but no 71 w-30 4spd cars came with ac right?
Old Jun 3, 2009 | 12:21 PM
wmachine's Avatar
http://www.oldsmobilewiki.com/index.php/Category:Cams
You can check out the stock cam specs yourself.
A custom grind is not a bad idea, though. Can be more tailored to exactly what you want.
72allblackcoupe
Apr 6, 2014 07:20 PM
1carsick
Brakes/Hydraulic Systems
23
Oct 2, 2012 05:50 PM
Last98
May 14, 2012 12:13 PM
russell-t
Apr 30, 2011 05:56 AM
Uly49
Oct 20, 2009 07:11 PM
