Ac to not ac
Ac to not ac
My 1969 455 donor engine is from an ac car, going into a non ac car, same year. What do I do with the water control valve? Should I just plumb it up, remove it, replace it with something else? I am not sure exactly its function, or operation so not sure how or if to circumvent.
thanks,
bob
thanks,
bob
Are you referring to the part (heater control valve) located here>>> https://classicoldsmobile.com/forums...rol-valve.html
We'll see what others have to offer, but I would 'suspect' if the vehicle you're installing this 455 into has no a/c, then you don't even need the heater control valve, IMO, and you can simply install a proper end-cap plug (of which, I believe they are of a normal water pipe fitting made of brass and obtained at a local h/w store).
I have it hooked to the heater core. It has a vacuum line on the end. I assume that for this application it needs to flow wide open always so water can circulate. Don't know of it will flow open if I leave it like this, or if my assumption. Is even correct.
A couple good thread posts to read which describe the operational features of the HCV. In particular, note they have changed over the years from what is a default 'open' condition, to a default 'closed' condition. But again, if the car you're dropping the 455 into has no AC, I'm suspect you don't even need the HCV.
https://classicoldsmobile.com/forums...s-supreme.html
https://classicoldsmobile.com/forums...ater-help.html
