ac help??
Old Feb 22, 2010 | 04:20 PM
71cutty's Avatar
Question ac help??
I retro fitted my ac system cause it was a pain in the a** to find R12 and now its not blowing to cold......i didnt find any leaks and its still holding pressure... what do you think the problem can be???????? thanks for your help!!
Old Feb 22, 2010 | 05:54 PM
mugzilla's Avatar
is Fast Enough ...
Ambient air temp sensor should be by the heater/a,c. air inlet ...
Old Feb 22, 2010 | 06:26 PM
71cutty's Avatar
Talking
ima try that tomorrow
Old Feb 22, 2010 | 07:30 PM
meoff's Avatar
at first glance I wondered who in the heck is running a/c this time of year
I see your in florida so weather must be getting nice quickthe wife and I are gonna run down to the cocoa beach area real soon!
but back to your Q.what all did you change?I'm guessing you went to
r-134a.what did you change accumulator,evaporator,condenser,compressor,orific e tube.
if only a couple were changed then which ones and did you drain oil and flush each one individually?
was a good vaccum pulled before charging?need some more info to accurately help
Old Feb 22, 2010 | 08:00 PM
OLDSRALLYE350's Avatar
Does the a/c compressor kick in ? What does the hi and low side on the gauges read?
Old Feb 23, 2010 | 04:47 AM
71rocket's Avatar
car nut farmer
Good thread. What is that large fitting in the line near the firewall? Where are the orafice and accumulator located? Pictures would be great (I'm big on pics). thanks.
Old Feb 23, 2010 | 05:55 AM
71cutty's Avatar
i didn't change anything i didn't think i had to. all i basiclly did was drain the r-12, put new oil in and add the r-134
Old Feb 23, 2010 | 06:21 AM
You MUST install new hi and low pressure hoses, orifice tube, and receiver dryer. Troubleshooting why your AC doesn't blow cold will be a moot point if these aren't changed.
When I retrofitted the R12 AC on my 1990 Buick Estate Wagon I changed all of the components above, pulled a vacuum on the system to make sure everything was sealed and then I added the PAG oil. After I added the PAG oil I pulled a vacuum on the system again and then charged it. Once the system was charged it worked ok.
An R12 system with R134a isn't going to cool as well as originally. You need an oversized condensor and evaporator for better efficiency. It will work ok though.
Old Feb 23, 2010 | 07:12 AM
dc2x4drvr's Avatar
Did you remove the brass cup from your expansion valve? It sits at the bottom of the valve and can be removed with an allen wrench.
Old Feb 23, 2010 | 09:34 AM
Lady72nRob71's Avatar
POA valve or STV (depending on year) must be removed and recalibrated for 134 for proper pressure. Classic Auto Air has lots of good info on the conversion process.
Old Feb 23, 2010 | 10:18 PM
mugzilla's Avatar
is Fast Enough ...
T M I ...
nice ...
nolabigdawg
Nov 16, 2014 06:45 PM
MJAKS462
Apr 15, 2010 02:34 PM
silverriff
Mar 24, 2010 06:36 PM
martine
Jan 22, 2009 01:13 PM
ToronadoGuyDenver
Brakes/Hydraulic Systems
Mar 18, 2007 02:52 AM
