84 307 timing tab ?
Old Jun 28, 2016 | 07:40 AM
Octania's Avatar
84 307 timing tab ?
VIN 1G4AP69Y0EH957xxx
1984 307 surely has larger rubberized damper right?
trying to get a guy the right timing tab
<li class="headline">1984 Buick LeSabre Limited
  • VIN: 1G4AP69Y0EH957xxx
  • Style / Body: Sedan 4D
  • Engine: 5.0L V8 4BBL
  • Country of Assembly: United States
says the VIN search
Old Jun 28, 2016 | 07:58 AM
quaddriver's Avatar
4 Barrels of Laughs
From: I moved to pittsburgh so I can be near Primantis
the 260 and the 307 all shared the same balancer according to my catalog - which may or maynot suck (the catalog, not the motor, well....ok perhaps the motor too)
anyways, they are iron pressed on the hub with super rubber but I do not think of a design where the counterweight moves much at all with vibrations, such as found on a diesel flywheel etc. more like a boat prop setup.
anyways, it appears from your post that you want the little plastic tab that bolts drivers side, down low thru the timing cover face and water pump with the degrees on it?
I so far have found no online parts source....not saying it does not exists, just not yet.
adding: gm part 419048 - discontinued, fits every damn olds iron v8 but the 307....figures
Old Jun 28, 2016 | 08:20 AM
CRUZN 66's Avatar
Olds Fever
I believe I have NOS Tabs for the 307... I will check the part number application and let you know...
Old Jun 28, 2016 | 08:42 AM
CRUZN 66's Avatar
Olds Fever
My computer parts system shows PN:550411 for an 84 Buick LeSabre w/ 307 engine... Fits 82 thru 90...
My inventory shows 3 in my NOS stock... I will have to check to be certain and physically put my hands on it... My price will be $25 plus S/H...
There's no doubt you can find one in a salvage yard, possibly for a lot less money since the tab fits 82 thru 90 full size Buick & Olds with the 307, as well as any G-Body w/ a 307...
Steve O
Dec 12, 2008 09:22 AM
timothypaul
Oct 15, 2008 09:18 PM
griz
Sep 24, 2008 05:09 PM
Ducman
Nov 14, 2007 09:21 AM
Huron
Jul 12, 2007 06:02 AM
