8.2 posi spider gears
Well that's because the ring gear bolts to the flange on the outside of the carrier, which is the same for both open and posi carriers. The internal guts are what's different between an open and a posi carrier. I do not know specifically if the spider gears on an 8.2 are different or not. The side gears on a clutch type posi are different as they have notches on the outside to engage the clutches and steels, but if the 8.2 is a cone style then I don't know.
