77 Olds Omega 4 door, wasting my time?
I recently posted a few pictures of a 1977 Oldsmobile Omega with 19,000 orignal miles on it in the newbe forum. My short term intent is to get this car in decent running condition for my 16 year old daughter, and if it survives her, then I would like to restore it at a later date. The car has not run since 1989, but has been in a garage the entire time. The motor is not siezed up, and initial assessment looks fairly good (No rust anywhere, just extremely dirty.
Question is, I have a budget of about $3500.00 to get it in good running condition. Is it reasonable to think that is enough $$ or am I wasting my time?
Any thoughts?
Greg
Any thoughts?
Greg
If you do it yourself and get help from these knowledgeable people on this site no problem I'm 16 and building my omega just 55 more dollars and I've practically have a car minus breaks and radiator
$3,500? You could buy two whole Ωmegas for that.
What could you possibly need to do, provided it doesn't have any major flaws, like a blown engine or transmission?
Cooling system flush, antifreeze, oil, oil filter, rear end oil, carb cleanout / rebuild (rebuild kit, float), fuel filter, air cleaner, cap, rotor, spark plug wires, spark plugs, belts, hoses, tires, probably a master cylinder and wheel cylinders.
Maybe fuel lines and brake lines, maybe drop the gas tank, maybe find a radiator leak.
I'm thinking $500, not including tires, $1,000 absolute max, with the tires another $500 or so.
Save the rest of the money for booze for you and your wife for when your daughter stays out late and doesn't call.
Do it and have her help you work on it. Don't worry about how good it turns out, her working on it will allow her to appreciate things she might not have thought about before. It won't be a waste of time if it helps her later.
I started restoring my 72 with my dad when I was 15 and I'm 18 now. It helped me learn how to set reasonable goals within a budget and got me serious about engineering. Not to mention, it makes you start thinking about how aspects of design affect our society. It was probably the best damn thing he could have ever done for me.
It's from the fim "Repo Man" starring Emilio Estevez, from 1984, one of the greatest car films of all time (in some ways, anyway).
Every vehicle in the movie has a pine tree air freshener, including the LAPD motorcycle, and at one point, the character who works at the repo yard clearing junk out of the repo'ed cars, who, if I recall, wears them around his neck, says "Every car's got one..." as he finds another one.
It's worth seeing, especially for a young person, and especially now that nobody has to waste their time with tapes or DVDs anymore.
Hell, I think Maximum Overdrive is one of Esteves's best car movies.
Jed, glad you like engineering. Engineering school will kick your butt. Let me know if you need advice on how to live through it.
As for the Omega, it's going to be her car, of course it matters if she wants it. Way too many people assume that the favors they do people are going to be automatically loved. Some people might hate that car so much that they'd rather earn enough to buy their own than drive it. But, yes, get her involved NOW. Like, this minute. Like "honey, here is this car, and I'd like you to have it. Here's our budget, and now let's talk about getting it running." It will be the heap she and her dad fixed up to her forevermore after that, and she won't keep it forever, and it won't be worth crap, but she'll value it.
The daughter is all in, she loves "old cars", just hard for me to get my head around a 1977 car being "old".
BTY Jed, Engineering school is worth it. when you get out, try finding a smaller company doing real engineering instead of a "Lock..d", "Boing", or a place like that. You'll learn more in 5 years than an entire career at the big firms. Save those places for later in life.
I have worked both, and writing requirements is not engineering.
I'd rather spend a couple of grand on a car that's got no sensors or electronics to fail. With our older cars ... if it's not running .. it's coz you broke something. Not because one out of 7000 sensors goes menstrual.
Keep in mind any 16 teen year old will change their mind in a heart beat, if their friends say anything derogatory or anything else comes up the car will be on the outs. My `daughter wanted a cute little two seater sports car for her 16th then found out it didn't seat 6 comfortably Sometimes you can't win....Tedd
Thanks for the advice Professur, I had a recent data point on the sensors with my 2006 Dodge truck. After much debate on the symptoms, came to closure on a intermittent TPS, even though no engine light, no engine codes.
Friend of mine got a deal on a set of fancy factory HID headlights for his E46 BMW from a junk car, so he put them in.
Easy swap.
They didn't work.
Turns out that in order to swap headlight types, the body computer has to be reprogrammed for it, which can only be done by the dealership's fancy proprietary computer.
He put the old lights back.
Now they don't work either - no highbeams, and they act weird.
This kind of crap drives me crazy.
Easy swap.
They didn't work.
#32
Standard method for a daily driver Whoa, Go, Show. Visual inspection to ensure it's structurally safe, then hit the brakes hard. If the lines are at all questionable ... rip and replace. That new nicopp brake line material lasts forever, is dead easy to work with ... and believe me ... when you're handing the keys to your little girl ... that's one thing you don't every want to be responsible for overlooking. Take a good look around the clamps. My Parisienne had a double line failure where the lines from the master cylinder clamped to the frame. I'd just rebuilt the tranny and had the rear end off the ground to do some testing. Took about half an hour for my hands to stop shaking.
#33
tannerblackart
August 11th, 2014 06:41 AM
Slater442
November 23rd, 2012 11:29 PM
