74 omega motor mount question
Olds motors in Omegas did not use the clamshell mounts. They used conventional frame pads with 2328 motor mounts. Naturally, the frame pads for the first gen Omega with an Olds motor are unique to that application - P/N 413004 and 413005 for RH/LH. The second gen Omegas (which use a subframe similar to that in the second-gen F-body) used one P/N 419637 (same as the 73-77 A-body) and one P/N 551721 (unique to the Omega).
The first gen cars use rear-steer, so the motor mounts bolt to the front two of the three holes in the side of the Olds block. This will determine where the frame pads go. Given the fact that you will be hard-pressed to find the correct original Olds frame pads, you might be stuck with using the Chevy clamshell mounts and getting a set of 77-79 Trans Am engine brackets to mate to them.
Nova should be the same. To be honest, I'd bolt the block to the trans, put the trans in the correct location relative to the crossmember, bolt the brackets and clamshells to the block, and see where they fall on the crossmember. This assumes you've got a trans that matches the crossmember, of course. The X-body only came with a TH350, so a TH400 won't be in the right place with the stock crossmember. Just be aware of that.
The trans mount on the TH400 is further back from the bellhousing, so you'll need the crossmember to be in the correct place to get the motor mounts right. The easiest thing to do is to temporarily bolt a TH350 to an Olds block, use your current crossmember, and use that to mock up the motor mount position. TH400 crossmember top, MT and TH350 bottom in the photo below.
1978 Oldsmobile Omega
June 5th, 2014 06:06 PM
78 omega 468
November 19th, 2011 10:03 PM
