72 U code, overflow tank?
Old Jan 12, 2022 | 06:42 PM
GN1220's Avatar
Did the 455 cars come with a stock overflow tank?
Old Jan 12, 2022 | 07:28 PM
It is my understanding it was a dealer fix for overheating big block cars, installed no charge upon complaint.
Old Jan 12, 2022 | 08:32 PM
GN1220's Avatar
So what is used as an acceptable tank? I just discovered my car has a spray bottle for an overflow, not something I want to keep.
Old Jan 12, 2022 | 08:51 PM
v8al's Avatar
Registered Olds Owner
See this:
Coolant Overflow Package, 1968-72 Cutlass and 442
Old Jan 13, 2022 | 05:46 AM
RetroRanger's Avatar
72 Olds CS
Dorman sells many varieties of overflow tanks. Many of us have adapted one to our vehicles. Mine was about $20. This wont do if originality is a concern.
Old Jan 13, 2022 | 06:06 AM
GN1220's Avatar
Since the cars didn't come with one originally it seems anything could be stuck on there as nothing would be considered original. I like the $20 option much better than the $230 option.
Old Jan 13, 2022 | 08:41 AM
There was a GM designed system. Fusicks sells a replica. This is what could be considered an original-style replica of a dealer accessory.
Old Jan 13, 2022 | 09:36 AM
Reservoir Package, technically listed for the 1971-72 cars. Interestingly, for 1970-earlier, all BBO A-body cars had the windshield washer tank mounted on the passenger side inner fender due to the larger R71 battery. This conflicted with the overflow tank placement. In the 1971 model year, The washer tank stayed on the driver side for A-body cars with BBO and RPO Y72 HD cooling. I believe the 71-72 tanks have a notch to clear the corner of the R71 battery.
Old Jan 13, 2022 | 10:05 AM
72 Olds CS
me too!
there are also many options availible on ebay, ive seen some nice aluminum ones that may cost more than the plastic dorman tank, but look more modern.
Old Jan 13, 2022 | 10:09 AM
I put the Fusick 200 dollar one on my H/O. The bracket is good, the bottle is good, the hoses are good, the lid fits tight but is a little unfriendly.
I upgraded to more sping clamps and used machine screws and nylocks over sheet metal screws for assembly.
Old Jan 13, 2022 | 10:12 AM
72 Olds CS
Heres a pic that shows my dorman one, theres plenty of others from them, i just picked one and adapted it
Old Jan 13, 2022 | 03:05 PM
Yellowstatue's Avatar
I was lucky and found two or three factory tanks at flea markets. I bought two new ones at the dealer for my four speed cars. The hard part is finding the factory bracket.
Old Jan 13, 2022 | 04:54 PM
bccan's Avatar
For 35 years I’ve been using OE washer tanks as overflow tanks on small block cars (apparently), mounted exactly like the washer tank on the right fender liner in Joe’s diagram. IIRC some have been black, some “white” depending on the donor car’s model year. Worked and continue to work like a charm but not gonna get you any points at the Olds show.
rcrac3r
Jan 17, 2023 09:58 AM
Lee_A
Aug 1, 2020 07:38 PM
JIM'S w30
Apr 29, 2016 06:13 PM
bainer1290
Mar 30, 2014 09:02 PM
bunick
Aug 13, 2013 07:49 PM
