72 cutlass
72 cutlass
I have a 72 Cutlass "S" and im looking for a radiator core support does anyone have 1 with a picture available and for a decent price.
I also have a 70 Buick Skylark with a 350 Rocket and I wanna know why is is so difficult to to mount up andn what can I do to get this motor to mount correctly on the frame please help me out!
It does make a difference, the 4 core radiator is wider than than the 3 core, so the brackets that hold the radiator in place have to be the correct width.
I might have a toplate in stock, that's why I was asking...
can you take of a pic of the lower core support saddles that the radiator sits on? Or, measure the saddles.
As far as your Skylark, look carefully at the frame, especially under the battery mounting area, these cars are known for developing cracks where the crossmember is welded to the frame rail.
well actually I wrecked my car at my house lol I was taking it for a drive around the corner lol and pulled in the yard the brakes went out and hit the steel beam and bent the entire middle section plate where u pull the the latch for the hood to open and the hood is no good I dont think and the bumpers is dented bad........and I got a new bumper and hood so do you think I would need the entire core support???
Depends on whether or not is was damaged and how bad. Do a visual from underneath. Depending how hard you hit, you may or may not have pushed the radiator and the support back. Did the radiator get pushed into the fan blade?
Sounds like you might need another core support if the top portion is bent, they're hard to straighten. Pry the hood up so you can see the damage. Alas, your bumper brackets are probably bent.
Here is the other pic please email me ikeepsitthorough@yahoo.com and let me know because i have to pay for it tomorrow!
Thanks 1969w3155 i was to be like damn i was happy for no reason.......lol but i got it for a really good price 147.50 from ebay and about 65.00 to ship from salem illinos to pine bluff,ar
This is a side profile of my '71 Supreme, note the squared off roofline and rear fenders. The "S" has the fastback style roofline and rounded rear fenders. 1970-1972 body styles only. Then again with the new colanade styling, this was repeated from 1973-1977. The pre '70 bodies were the same, and it was a trim option, with the Supreme generally more upscale.
@1969w3155 if I purchased 2 new motor mounts to put on the motor of my 68 cutlass 350 engine what would I need to do to make it fit for the 70 Buick skylark frame or would I have to fabricate some things
looking for a 350 engine
im looking for a good block for my 71 cutlass that I just bought from Murfreesboro Tn and I live in Pine Bluff ,Ar not looking to travel that far
Last edited by DATRICANBOY; March 17th, 2010 at 03:18 AM. Reason: not enough words
