72 cs transmission gasket
I am in the process of changing my transmission gasket and filter. After loosening all the bolts on the transmission pan the back park will not drop. I have the front just hanging. It's like something is holding it in place. I notice there is a long bar that runs from one side of the door to the other side above the pan. Did I forgot to do something or should the pan drop after taken out all the bolts.
If memory serves, that the rubber mount for the trans tail shaft/crossmember has compressed or failed to the point of lower height, less clearance. You can loosen the mount hardware and have someone help by prying up on trans and it should come out. Just make sure that your holding the trans pan so you don't get a bath or make a mess when it drops into your drain pan!
Pat
Pat
I would not! If you do it may get sealant into the transmission.
Usually they fold the damn gaskets now days instead of the old days of laying them flat on the cardboard with filter in center and shrink wrapped.
You may want to lay the gasket down on flat clean surface and put weight on it for a while, to help take the wrinkles out of the gasket. FYI when removing the old filter, make sure that the O-ring comes off with filter, if not it will be stuck in the bore. Remove with a o-ring pick or pocket screw driver.
Pat
Pat
I just did this in my 72 Cutlass "S" two weekends ago. Pan came right down, I didn't have any kind of rod under the pan.
Just had to be careful with the linkage bolts, didn't want to bend them when putting them back.
aussiemobile
February 15th, 2013 07:31 AM
harry k
November 21st, 2012 08:54 AM
dallasite21
June 20th, 2010 05:37 AM
