72 Axle free play question
Old May 13th, 2013 | 08:04 PM
Edzx6's Avatar
I posted this message in newbie section by mistake. I have a 72 Cutlass I changed ring and pinion, installed new brake drum kits and lines and lastly replaced seals, bearings and retainers on old stock axles.
The problem now is after installing axles I have about 1/4" in and out free play. What could be causing this excessive free play? Attached a pic if this helps? Bearings and retainers are fully pressed in, this are not "C" clip axles. I'm stuck please HELP!!!
Old May 13th, 2013 | 09:02 PM
I see a shiny area on the axle shaft between the seal and the retainer. Perhaps the bearing/seal is not pressed fully onto the axle shaft?
72hurst
Drivetrain/Differentials
April 21st, 2014 05:34 PM
68conv455
January 12th, 2009 07:58 PM
sx455raidercelticfan
October 10th, 2008 06:54 PM
68conv455
August 4th, 2008 08:05 PM
