72-73 Rims
Old Oct 9, 2012 | 01:14 PM
rcrac3r's Avatar
72-73 Rims
Are the rims on the 72 & 73 Cutlass the same? I have a line on a 73 Cutlass parts car that might have some Olds rally rims on it that I would like to put on my 72.
Old Oct 9, 2012 | 01:25 PM
oldsmobiledave's Avatar
Fyi
The SS 111 rim from 1973 is identicle to the rim from 1972.
If you just want rims I have 5 SS 111 rims with center caps & trim rings that I took off my 72 W-30 last spring. They will need to be sprayed argent silver or viking blue to go on your car (rims are currently Radiant Green). Just rims as I sold off the 20 year old tires to someone to use for storage tires on their rims.
I am in Cochrane. PM me if interested.
Old Oct 9, 2012 | 02:52 PM
Dave Siltman's Avatar
Correct me if I am wrong, but I think '73 would have had 15" wheels.
Old Oct 9, 2012 | 03:09 PM
oldspackrat's Avatar
Dave,
I think you're right, the '73 & maybe '74? had the 15" bolt on center cap SS II's. Those are highly sought after wheels.
Old Oct 9, 2012 | 03:19 PM
I think your question is more relative to the mounting bolt pattern? If it is, yes that's a direct swap. Chances are good you can get all the wheels fairly cheap if it's a parts car. I would only pay around 15-20 each for them at pick and pull. You were a mechanic so you know how to test for true. I think they would really dress up that sedan! Oh, if they each have the 5 trim bezels, that's even better. You can get aftermarket trim rings for them.
Old Oct 9, 2012 | 05:16 PM
Fyi
14" rims with bolt on caps 1970-1973
15" rims with bolt on caps 1974
15" rims with snap on caps 1975-1977
consider yourself corrected...
Old Oct 10, 2012 | 09:54 AM
Never too old to learn
LJA72
Jan 31, 2014 08:02 PM
grindlecrew
Mar 2, 2013 04:19 PM
CutlassLegend
Care and Appearance
Aug 6, 2011 11:08 PM
