72 350 intake question
The information below is from Chris Witt's detailed archive. It shows the #16 intake manifold with "OLDSMOBILE" is a 1973-1976 application. Note that it has an EGR valve flange on the drivers side exhaust crossover.
There will be a casting number on the runner behind the carb. pad., Google that number, or post it here, and you will get the original application..
By the way, your oil pressure hose is leaking. You should swap that out for the brass hose, or better yet, a braided steel hose and fittings.
