72 350 intake question
Old Nov 15, 2021 | 10:32 AM
Marguar's Avatar
Hello - just curious, can you tell me about my “Oldsmobile” intake manifold? I haven’t seen any with the word Oldsmobile actually on the manifold.
Old Nov 15, 2021 | 12:25 PM
The information below is from Chris Witt's detailed archive. It shows the #16 intake manifold with "OLDSMOBILE" is a 1973-1976 application. Note that it has an EGR valve flange on the drivers side exhaust crossover.
Old Nov 15, 2021 | 12:32 PM
70W-32's Avatar
There will be a casting number on the runner behind the carb. pad., Google that number, or post it here, and you will get the original application..
By the way, your oil pressure hose is leaking. You should swap that out for the brass hose, or better yet, a braided steel hose and fittings.
Old Nov 15, 2021 | 12:44 PM
That looks like an electrical sensor to me in the picture and the leak could be the sensor or the intake manifold front seal.
Old Nov 15, 2021 | 12:51 PM
The intake is 1973-newer. I'm guessing it has a boss for the EGR valve on the driver's side.
oldsmobilejim
Nov 24, 2020 09:18 PM
old442x3
Mar 8, 2018 04:09 AM
airborne1942
May 9, 2017 07:07 PM
simpleold
Aug 17, 2016 05:07 PM
