70 W-30 on BAT
70 W-30 on BAT
What do you guys think about this one?
https://bringatrailer.com/listing/19...le-442-w-30-5/
100k for incorrect stripes on the sides and the deck lid. It has Cutlass tail lights. Terrible fit all the way around.. Just a couple things I notice right away. Why is it so difficult to get W stripes right? Does that block stamp look legit?
That stamp doesn't even look like a stamp. It looks like a raised embossed deal. Totally incorrect.
It's at least a 442 by the VIN, but that's all. Couldn't tell if it's a genuine W car. Transmission tag and stampings, if true, may be something to consider. At least that stamp looks more close to a stamping vs that block fiasco. The paperwork can be reproduced. And paperwork that looks that cruddy makes me wonder what the rest of the car looked like prior to restoration. The stripes SUCK. Someone obviously didn't do ANY homework. The 442 emblem holes all around have been redrilled incorrectly which puts the emblems with incorrect alignment/spacing. To me, those sort of details matter for that kind of money.
That said, I'd cruise this missile around town no problem, but not at 95K.
https://en.wikipedia.org/wiki/Crater_illusion
And I wasn't claiming you were claiming that. I was just pointing out the discrepancy with a stamping that probably shouldn't even have been there in the first place. If you replace a block, to me it's not prudent to restamp a non-original engine with the car's original stamping. It's not like it's a casting number.
But raised numbers have been done before. Chris Witt used to make "fake" 69 H/O intakes and F heads with reconstructed raised numberings. But he also advertised them as such.
Then again, you'd also expect them to know which way the valve covers go, so there's that...
Big difference between creating molded raised characters using JB Weld and sand on a cast intake that's then painted and creating metallic raised characters on a bare cast iron machined pad. And let's be serious here. Anyone who knows enough to put a fake VIN derivative on a block also knows that the VIN derivative is a stamp, not raised cast characters.
The transmission tag and stamp derivative would need further inspection, but at first glance they seem to be genuine-looking. Spacing/depth/alignment seem to be in order.
My luck if I tried to fake the numbers and put crappy stripe job and number piercings, I couldn't get $30K out of the car.
Likely for the same reason that my 70 W30 4spd had a 3.08 anti-spin in it when I got it. Lots of people swapped out rear axles in the mid-70s during the gas crisis. FYI, a 4spd and 3.08s don't make for clutch longevity. Of course, neither did the five grand holeshots.
If you're going to bother to fake it, at least try to get it closer to correct. There's no good reason on earth you would want to restamp that pad other than to make the unsuspecting think that it's a "numbers matching" engine. It's one thing for an owner to do it for him/herself just because. But it seems to me the seller is in this to make a buck from the get-go. Makes you wonder what else was half-assed.
What about this one:
https://bringatrailer.com/2019/03/27...-w-27-4-speed/
If its legit, thats a nice car worthy of any Olds collection. Reminds me of Lee Pearl's
