70 Sport Mirror Install -
I have a set of factory 70 Sport mirrors. I am still not sure I will install them, as I like the chrome mirror on the driver’s side, and it will not be original (but yes never liked the pass side w/o a mirror). If I put them on, are there any tips , things to look out for. I will need to drill the pass side door, so I am planning to drill the holes for the studs only w/o the slots like the driver’s side.., using the CL whole locations on the driver’s side. thanks
I drilled the passenger door with same dimensions as drivers but in reverse. To prevent passenger door from flexing from the mirror, you can buy a support bracket like the factory used. Inline tube or others sell it. I Tack welded mine on the inside of door but it was before the paint shop. if your car is already painted you can maybe pop rivet this bracket.
October 16th, 2013 05:35 PM
stlbluesbrother
December 24th, 2009 05:47 AM
