70 olds 455 timing issues
Old Dec 10, 2010 | 01:47 PM
jkoester122's Avatar
ok guys i got the timing tab on and it hooked up to timing light it was all the way to the right notch.... it was still knocking when turned off. ive been researching online about which way to rotate distributor to advance or retard the timing on an olds 455, i found that chevys are counter clockwise to anvance and have heard that oldsturn clockwise to adnace the timing. i get it to where it doesnt knock any more when shut off but the mark is off the tab to the left. or get it to where the knotch is off the tab to the right abd doesnt knock, on the tab seems to knock,, need help. please respond
Old Dec 10, 2010 | 04:47 PM
svnt442's Avatar
You have the tab. With the engine running set the initial to 8° and start from there. you can advance it to 10° - 14° depending on what the engine likes, but I would probabaly stay no more than 12°.
Old Dec 11, 2010 | 03:52 PM
thank you we figured out which way to rotate it and got it all figured out!. it had something to do witht the scres on carb taht adjust with a spring also flushed radiator and is now running about 175-180
Six8 x 43
Jun 8, 2015 07:52 AM
jkoester122
Sep 1, 2011 06:39 AM
crholds442
Dec 8, 2010 08:16 PM
442scotty
May 13, 2009 05:42 PM
cisco88
Jan 26, 2009 05:54 AM
