'70 Cutlass Speedo is not working...
Old May 16, 2019 | 12:41 PM
BSiegPaint's Avatar
OK - so a few weeks ago I got the car out for the first time this year. The speedo worked fine for about 100 yards, bounced, then went dead. Never came back. Today I replaced the speedo (a planned change out), and the speedo cable. The driven gear was replaced last fall when I was calibrating my other speedo. I quickly ran the new setup to make sure it worked, and it was smooth up to the 80 mph mark my drill would take it to. Everything fit together today as it should when installed. Got the car off the jacks and went for a ride and it was deja vu. The speedo worked for about 100 yards, bounced around and stopped working. So I'm not sure what's wrong or what to check first. I didn't troubleshoot the old set up because I had already planned to replace it. Where would you start?
Old May 16, 2019 | 12:45 PM
Originally Posted by BSiegPaint
The driven gear was replaced last fall when I was calibrating my other speedo. Where would you start?
Look at the drive gear on the output shaft. Likely it's excessively worn.
Old May 16, 2019 | 12:46 PM
BSiegPaint's Avatar
Which would be my luck since I have a 4-speed...
Old May 16, 2019 | 06:36 PM
BSiegPaint's Avatar
It was the driven gear - chewed to a nub. I know the drive gear isn't the right one - I think in trying to get the mph correct I matched up two angles that weren't compatible...
Via3d
Sep 23, 2018 10:42 PM
Michael Amrhein
Mar 15, 2017 05:00 AM
1BOSS83
Jan 15, 2014 05:14 PM
delta254
Drivetrain/Differentials
Oct 18, 2012 10:11 PM
Pfiffle
Mar 13, 2008 11:22 AM
