70 cutlass "s" boxed control arm's factory???
Can anybody tell me if my car came with boxed control arms from the factory??? .
And is it possibly the motor could be original to the car i cannot find a build sheet or the numbers on the block by the front of the block on the pad .
it does have e heads and an f block.
It's the only way to tell whether your engine is original.
Thanks i did so pitted cannot read it!!!
any suggestions grind it wet etc...???
You need good access to the pad where the stamping is.
First I would recommend a good degreasing with lacquer thinner, mineral spirits, or similar.
Next, I would try a wire brush, preferably something powered, like a wire brush wheel on a drill, or on a Dremel MotoTool.
Once you have the grease and loose stuff off, you should be able to see it.
If not, you can use some fine sandpaper by hand to try to remove high spots and bring up the stamping.
Another possibility, once it's good and clean, is to do a pencil rubbing of it - sometimes you can't read it on the metal, but you can on the paper.
great advise as soon as i get the car back from the body shop i will get alittle more personal with that pad and hopfully find out that it is.
then i might be sorry i didnt go with the original color ooops!!!
that's ok. I'm going with agean aqua....
Well... Looks like you may have to take some things apart.
marxjunk
July 13th, 2014 09:53 PM
ros6872
February 12th, 2014 04:20 AM
81 regency
April 21st, 2011 07:18 PM
oldzy
Suspension & Handling
June 12th, 2010 11:02 AM
