70 Cutlass exhaust manifold removal (RH)
mix 50/50 acetone and automatic transmission fluid and apply to the bolts... let them sit for a while then do it again. You will need to flatten the locking tabs on the
u shaped clips that go under the bolts... (If you have a crud build up they are hard to see the locking tabs.)
