70-72 Part question
Old Jul 12, 2020 | 06:26 PM
scrappie's Avatar
70-72 Part question
Just to make sure but I want to verify the rear molding near the windshield on a OAI hood is the same as a regular hood? I heard in the past the OAI molding has a wider opening due to fiberglass and metal in contrast to two layers of metal on a standard hood. Anybody know anything about this?
Old Jul 12, 2020 | 07:44 PM
4speed455's Avatar
I believe they are the same but not sure. I know I just used the original piece from my stock metal hood on my repro w25 hood. I had to open it up quite a bit to fit over the fiberglass. I’m sure the aftermarket hood is much thicker in that area then the OEM w25 hood and I was still able to make it fit. If you found one off a factory w25 hood it would probably fit better, but I believe the metal hood trim can be opened up enough to fit.
Old Jul 13, 2020 | 05:26 AM
My442's Avatar
Same part on both hoods.
Old Jul 13, 2020 | 06:27 AM
The parts book lists only one P/N for all 1968-72 Cutlii: 398616.
Old Jul 13, 2020 | 06:35 AM
scrappie's Avatar
Thanks gents!
rsw4723
Jul 11, 2020 03:20 PM
kbdecatur
Feb 10, 2019 12:20 PM
kbdecatur
Feb 6, 2019 04:09 PM
nelsontj
Aug 8, 2013 05:55 PM
RetroRanger
Sep 22, 2012 06:12 PM
