69 cutlass frame?
Old Jan 1, 2013 | 06:38 PM
Bernhard's Avatar
69 cutlass frame?
Frame?
Are the 442 and cutlass frames the same as in thickness?
Is there any difference in the frames?
Old Jan 1, 2013 | 06:42 PM
compedgemarine's Avatar
they are the same and are the same frame as 68-72 A bodies such as skylark, chevelle, tempest, etc. there is a difference from convertibles to hardtops.
Old Jan 1, 2013 | 07:33 PM
Bernhard's Avatar
I was thinking they were the same. I was told by some car fanatos that the Buick GS had a stronger frame than the skylark and that the 442 came with a stronger frame as well.I know that the GS had extra bolt on braces cant remember if the 442 had the same. I know GM boxed the convert frame.
Thanks for the reply.
Old Jan 2, 2013 | 07:22 AM
Performance versions of the A-bodies had bolt-on braces that ran between the attach points for the upper and lower rear control arms. Hardly a "stronger frame" and a part that is easily bolted on to any A-body.
Old Jan 2, 2013 | 08:26 AM
Run to Rund's Avatar
The story of the GS400 Buick seems to be that convertible frames were used on the early model years. I have not tried to verify this. Olds offered the same frame as option F35, cost $12.53 in 1966.
Old Jan 2, 2013 | 09:16 AM
Bernhard's Avatar
I concur
You know when people talk with such conviction it makes you sometimes doubt your own common senes.
oldsmobilty
Sep 27, 2012 04:26 PM
sixty9olds
Jun 14, 2011 06:43 PM
1969goatman
Aug 30, 2010 07:44 PM
DJMatthews
Dec 5, 2006 01:28 PM
