69 442 Carburetor Numbers
This is my carb number (#7029253) on my Fremont CA built 1st week of January 69 442. It appears the date code is 156th day of 1970? Reference charts show all 1970 carbs start with #704 not #702? I'm trying to figure out if this is the correct number for my auto trans car. I am getting different numbers from multiple source guides. A 69 442 buyers guide from hemmings muscle machines says #7029251 is the MT carb. Another guides says #7029251 is the AT carb (except W-30-, W-32). This same guide says my carb #7029253 is MT and W-32. Another reference says my auto trans car should have carb #7038251 and the 400 is 350 HP. I thought the auto was 325HP and the manual 350HP. My car is numbers matching, just trying to figure out what carb # is correct.
Thanks!
Thanks!
What you have is what is called a "service replacement" carburetor. If you had carb issues and took your car to the dealership (or perhaps even a automotive repair shop) back in the day, most wouldn't deal with rebuilding your original carburetor. They would just get a service replacement unit that has the same carb part number but was clearly manufactured after 1969. For a '69 original carburetor there is also an "RJ" code which I've heard is called a "broadcast" code. In my experience, I've noticed service replacement carburetors generally do not have that code. I believe the correct carb for your car as a 4-4-2 with manual transmission should be 7029253.
Randy C.
'68 4-4-2 convertible
'69 4-4-2 convertible
Randy C.
Last edited by rcorrigan5; March 10th, 2023 at 07:40 AM. Reason: add last sentence
You are correct, Randy. As you noted, it should also have the RJ next to the 7029253 for an MT in a 4-4-2..
Crimson, is there a number punched on the driver side edge flange of the carb's base? There is usually also a Julian date code stamped there, like this. This is a 7028251 built on day 345 of 1967.
The 7029253 service replacement carb is probably the most common one out there. I have seen the following dates:
1560
1952
1962
0444
0514
0995
2226
The three drill or punch marks next to the carb number are also a sign that it's a service replacement carb and/or the carb has been rebuilt in the past
The correct carb for your 69 auto 442 is a 7029251 with a production date prior to your build date
1560
1952
1962
0444
0514
0995
2226
heres one that was recently listed for $150
https://classicoldsmobile.com/forums/parts-sale-11/various-leftovers-69-442-a-168314/
Nothing, but the seller claims that there are internal differences that he refuses to document, because, of course this is a big secret. The Rochester Big Book O'Carbs shows that all '9251s are exactly the same. Of course there's also the person who claims that 1968 Ram Rod carbs didn't get primary metering rods either.
