68 up power steering bracket spacer?
Can somebody help me with the size/dimensions for the spacer that goes between the P/S bracket and block on a 68 & newer Olds? It's not the one that goes on the front mounting stud for the P/S but the rear most mounting bracket.
Thanks in advance.
Mike
Thanks in advance.
Mike
Inline Tube sells the spacers as a kit, comes with both the front one and the rear. The rear is about the size of a nickel in outside diameter and probably about one quarter inch thick, maybe slightly more. Speaking from memory as it has been a while since I installed mine
olds70supreme
January 23rd, 2014 10:22 AM
xerxes600rr
August 30th, 2011 06:43 AM
