68 toro window issues
Old May 9, 2014 | 02:41 PM
setagus's Avatar
my hot wire is dead but I have power at the fuse box. are there any stops on the way to the door from the fuse box?
Old May 9, 2014 | 09:58 PM
2blu442's Avatar
I've not had a 1968 Toro apart, but the Cutlass has a relay behind the drivers side kickpanel. That's between the fuse box and the power window motor.
John
Old May 10, 2014 | 01:09 AM
Yellowstatue's Avatar
There is a thirty or forty amp circuit breaker under the hood that supplies power to the above mentioned relay. Relay is rectangular with two studs sticking out and a flat tab with two screws to hold it to the firewall. Two 10 ga. red wires (or possibly orange w/ black tracer) mounted under the studs of the circuit breaker. One wire from power source and the other to the relay. Key energizes relay and power is sent on it's merry way.
vistacruiser1971
Dec 27, 2012 07:35 AM
EightballZ
Nov 12, 2012 08:10 AM
deaddds
Mar 14, 2012 03:25 AM
StarGeneral
Body work
Jan 25, 2012 10:58 AM
FIJIBLUE72
Body work
May 6, 2009 04:58 AM
